Generating Random Permutations in the Framework of Parallel Coarse Grained Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Eric Thierry
  • Fonction : Auteur
We present three algorithms for generating random permutations in the coarse grained model CGM. For each of the proposed algorithms, we study the number of supersteps, the size of the local memory, the overall communicat- ion cost and we check if it gives a permutation with the uniform distribution or not. The proposed algorithms are intended to be simple and of practical relevance. The difficulty, in this paper, lies in proving that they are the desired properties.
Autre [cs.OH]
RR-3896.pdf (286.09 Ko) Télécharger le fichier
inria-00072758 , version 1 (24-05-2006)
  • HAL Id : inria-00072758 , version 1
Isabelle Guérin Lassous, Eric Thierry. Generating Random Permutations in the Framework of Parallel Coarse Grained Models. [Research Report] RR-3896, INRIA. 2000. ⟨inria-00072758⟩
150 Consultations
129 Téléchargements
