A Finite Buffer Fluid Queue Driven by a Markovian Queue - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Bruno Sericola
We consider a finite buffer fluid queue receiving its input from the output of a Markovian queue with finite or infinite waiting room. The input flow into the fluid queue is thus characterized by a Markov modulated input rate process and we derive, for a wide class of such input processes, an approach for the computation of the stationary buffer content of the fluid queue and so for the computation of the stationary overflow probability. This approach leads to a numerically stable algorithm for which the precision of the result can be specified in advance.
Autre [cs.OH]
RR-3883.pdf (193.67 Ko) Télécharger le fichier
inria-00072770 , version 1 (24-05-2006)
  • HAL Id : inria-00072770 , version 1
Bruno Sericola. A Finite Buffer Fluid Queue Driven by a Markovian Queue. [Research Report] RR-3883, INRIA. 2000. ⟨inria-00072770⟩
78 Consultations
118 Téléchargements
