Abstract : We propose an implementation and a proof of correctness of binary decision diagrams (BDDs), completely formalized in Coq. This not only shows that BDD algorithms are correct, but also yields a certified BDD algorithm running in Caml, using extraction, and even allows us to run BDD-based algorithms inside Coq itself, by reflection. The latter point paves the path for a smooth integration of symbolic model-checking in the Coq proof assistant. Extensive experimental results show that this approach works in practice, and is able to solve both relatively hard propositional problems and actual industrial hardware verification problems.
