Correctness of Java Card Tokenisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
We present a formalisation of the bytecode optimisation of Sun's Java Card language from the class file to CAP file format as a set of constraints between the two formats and define and prove its correctness. Java Card bytecode is formalised as an abstract operational semantics, which can then be instantiated into the two formats. The optimisation is given as a logical relation such that the instantiated semantics are observably equal.
Autre [cs.OH]
RR-3831.pdf (427.55 Ko) Télécharger le fichier
inria-00072826 , version 1 (24-05-2006)
  • HAL Id : inria-00072826 , version 1
Ewen Denney. Correctness of Java Card Tokenisation. [Research Report] RR-3831, INRIA. 1999. ⟨inria-00072826⟩
64 Consultations
145 Téléchargements
