A stochastic Model of TCP/IP with Stationary Ergodic Random Losses
Abstract : We consider here a flow control mechanism in which the rate at which data is sent increases linearly in time until a loss occurs. At that point the transmission rate decreases by a multiplicative factor. This mechanism is a good approximation to TCP/IP, the congestion control in the Internet. Losses are generated by some exogenous random process, which is assumed to be stationary ergodic; no Markovian assumptions are made. We obtain an explicit expression for the average transmission rate and obtain bounds in the case that there is a limit on the maximum rate.
Type de document :
Rapport
RR-3824, INRIA. 1999
Liste complète des métadonnées
Littérature citée [1 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00072834
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 11:04:03
Dernière modification le : samedi 27 janvier 2018 - 01:31:03
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:24:26
Fichiers
  • HAL Id : inria-00072834, version 1
Collections
Citation
Eitan Altman, Konstantin Avrachenkov, Chadi Barakat. A stochastic Model of TCP/IP with Stationary Ergodic Random Losses. RR-3824, INRIA. 1999. 〈inria-00072834〉
Métriques
Consultations de la notice
294
Téléchargements de fichiers
109
