Hierarchic Normal Forms for Desynchronization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Based on an earlier work, we present an in-depth discussion of the relationsh- ips between synchrony and asynchrony. Simple models of both paradigms are presented, and we state theorems which guarantee correct desynchronization- , meaning that the original synchronous semantics can be reconstructed from the result of this desynchronization. This theory can be used as a basis for correct distributed code generation. The present paper presents a new data structure, the hierarchic normal form for a transition relation, which is instrumental in implementing this theory. We illustrate this on a example. The whole approach is implemented in the Signal compiler.
Autre [cs.OH]
RR-3822.pdf (696.37 Ko) Télécharger le fichier
inria-00072836 , version 1 (24-05-2006)
  • HAL Id : inria-00072836 , version 1
Jean-Pierre Talpin, Albert Benveniste, Benoit Caillaud, Paul Le Guernic. Hierarchic Normal Forms for Desynchronization. [Research Report] RR-3822, INRIA. 1999. ⟨inria-00072836⟩
188 Consultations
119 Téléchargements
