Perturbation of Linear Quadratic Systems with Jump Parameters and Hybrid Controls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
Mohammed Abbad
  • Fonction : Auteur
Eitan Altman
  • Fonction : Auteur
  • PersonId : 830042
We consider the problem of the perturbation of a class of linear-quadratic differential games with piecewise deterministic dynamics, where the changes from one structure (for the dynamics) to another are governed by a finite-stat- e Markov process. Player 1 controls the continuous dynamics, whereas Player 2 controls the rate of transition for the finite-state Markov process; both have access to the states of both processes. Player 1 wishes to minimize a given quadratic performance index, while player 2 wishes to maximize or minimize the same quantity. The problem above leads to the analysis of some linearly coupled set of quadratic equations (Riccati Equation). We obtain a Taylor expansion in the perturbation for the solution of the equation for a fixed stationary policy of the player 2. This allows us to solve the game or team problem as a function of the perturbation.
RR-3816.pdf (269.56 Ko) Télécharger le fichier
inria-00072842 , version 1 (24-05-2006)
  • HAL Id : inria-00072842 , version 1
Rachid El-Azouzi, Mohammed Abbad, Eitan Altman. Perturbation of Linear Quadratic Systems with Jump Parameters and Hybrid Controls. RR-3816, INRIA. 1999. ⟨inria-00072842⟩
83 Consultations
215 Téléchargements
