HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Multimodal Brain Warping Using the Demons Algorithm and Adaptative Intensity Corrections
Alexandre Guimond 1 Alexis Roche Nicholas Ayache Jean Meunier
1 EPIDAURE - Medical imaging and robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This paper presents an original method for three-dimensional elastic registrat- ion of multimodal images. We propose to make use of a scheme that iterates between correcting for intensity differences between images and performing standard monomodal registration. The core of our contribution resides in providing a method that finds the transformation that maps the intensities of one image to those of another. It makes the assumption that there are at most two functional dependences between the intensities of structures present in the images to register, and relies on robust estimation techniques to evaluate these functions. We provide results showing successful registratio- n between several imaging modalities involving segmentations, T1 magnetic resonance (MR), T2 MR, proton density (PD) MR and computed tomography (CT). We also argue that our intensity modeling may be more appropriate than mutual information (MI) in the context of evaluating high-dimensional deformations, as it puts more constraints on the parameters to be estimated and thus permits a better search of the parameter space.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072863
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:07:48 AM
Last modification on : Friday, February 4, 2022 - 3:17:18 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:25:28 PM
Identifiers
  • HAL Id : inria-00072863, version 1
Collections
Citation
Alexandre Guimond, Alexis Roche, Nicholas Ayache, Jean Meunier. Multimodal Brain Warping Using the Demons Algorithm and Adaptative Intensity Corrections. RR-3796, INRIA. 1999. ⟨inria-00072863⟩
Share
Metrics
Record views
161
Files downloads
173
