Quality of Service and Electronic Newspaper: The Etel Solution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Making electronic newspapers available to users is an attractive business for newspaper editors. However, the success of an electronic newspaper in a commercial setting depends upon the provided quality of service. The newspaper must guarantee to its users, both content quality in terms of reading comfort, and access quality in terms of response time. This paper presents the Etel electronic newspaper whose main design objective is to guarantee high quality of service to users. Content quality is achieved through the design and production of electronic editions in close collaboration with a newspaper editor. Access quality is realized through the design and implementation of a dedicated client-server distributed system. The proposed distributed system exploits the specifics of electronic newspapers. Precisely, most newspaper readers systematically consult the various editions of their usual newspaper in the same way. In the context of an electronic newspaper, this means that we can safely assume the existence of user profiles in terms of access patterns to newspaper editions. This feature allows us to propose profile-based automatic prefetching and load balancing strategies, which together enable to offer a highly responsive and scalable distributed system.
RR-3795.pdf (470.34 Ko) Télécharger le fichier
inria-00072864 , version 1 (24-05-2006)
  • HAL Id : inria-00072864 , version 1
Valérie Issarny, Michel Banâtre, Boris Charpiot, Jean-Marc Menaud. Quality of Service and Electronic Newspaper: The Etel Solution. [Research Report] RR-3795, INRIA. 1999. ⟨inria-00072864⟩
190 Consultations
377 Téléchargements
