Reports
The Steam Boiler Controller Problem in Signal-Coq
Mickaël Kerboeuf 1 David Nowak 1 Jean-Pierre Talpin 1
1 EP-ATR - Environnement de programmation d'applications temps réel
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : Among the various formalisms for the design of reactive systems, the SIGNAL-CO- Q formal approach, i.e. the combined use of the synchronous dataflow language SIGNAL and the proof assistant COQ, seems to be especially suited and practical. Indeed, the deterministic concurrency implied by the synchronous model on which SIGNAL is founded strongly simplifies the specification and the verification of such systems. Moreover, COQ is not limited to some kind of properties and so, its use enables to disregard what can be checked during the specification stage. In this article, we underline the various features of this SIGNAL-COQ formal approach with a large scale case study, namely the Steam Boiler problem.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072888
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:11:05 AM
Last modification on : Friday, February 4, 2022 - 3:25:11 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:26:49 PM
Identifiers
  • HAL Id : inria-00072888, version 1
Citation
Mickaël Kerboeuf, David Nowak, Jean-Pierre Talpin. The Steam Boiler Controller Problem in Signal-Coq. [Research Report] RR-3773, INRIA. 1999. ⟨inria-00072888⟩
Share
Metrics
Record views
107
Files downloads
330
