HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Generalized Hamming Weight as a Weight Function
Dmitrii Yu Nogin 1
1 CODES - Coding and cryptography
Inria Paris-Rocquencourt
Abstract : We prove that the weight function of a linear code, that is, an integer function defined on the vector space of messages, uniquely determines the code up to equivalence. We propose a natural way to extend the r-th generalized Hamming weight, that is, a function on r-subspaces of a code, to a function on the r-th exterior power of the code. Using this, we show that for any linear code C and any integer r not greater than the dimension of C, another code C' exists whose weight distribution corresponds to a part of the generalized weight spectrum of C from the r-th weights to the k-th. In particular, the minimum distance of C' is proportional to the r-th generalized weight of C.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00072900
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:14:22 AM
Last modification on : Friday, February 4, 2022 - 3:10:23 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:27:08 PM
Identifiers
  • HAL Id : inria-00072900, version 1
Collections
Citation
Dmitrii Yu Nogin. Generalized Hamming Weight as a Weight Function. [Research Report] RR-3762, INRIA. 1999. ⟨inria-00072900⟩
Share
Metrics
Record views
81
Files downloads
241
