A Second-Order Bundle Method to Minimize the Maximum Eigenvalue Function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
In this paper we present a nonsmooth algorithm to minimize the maximum eigenvalue of matrices belonging to an affine subspace of n x n symmetric matrices. We show how a simple bundle method, the approximate eigenvalue method can be used to globalize the second-order method developed by M. L. Overton in the eighties and recently revisited in the framework of the U-Lagrangian theory. With no additional assumption, the resulting algorithm generates a minimizing sequence. A geometrical and constructive proof is given. To prove that quadratic convergence is achieved asymptotically- , some strict complementarity and non-degeneracy assumptions are needed. We also introduce a new generation of bundle methods for semidefinite programming.
RR-3738.pdf (444.67 Ko) Télécharger le fichier
inria-00072927 , version 1 (24-05-2006)
  • HAL Id : inria-00072927 , version 1
François Oustry. A Second-Order Bundle Method to Minimize the Maximum Eigenvalue Function. RR-3738, INRIA. 1999. ⟨inria-00072927⟩
66 Consultations
680 Téléchargements
