Shape Sensitivity Analysis of Variational Problems in Domains with Cracks - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1999
Gilles Fremiot
  • Function : Author
  • PersonId : 756523
  • IdRef : 118412116
We obtain the structure theorem for a differentiable shape functional defined in a domain including curved cracks. The theorem is an extension of the structure theorem given eg. in [15] in the case of smooth domains. Four examples of applications of our result are given for shape functionals defined for elliptic boundary value problems: to nonlinear elliptic boundary value problems, to optimal control problems and to the shape differentiability of the first eigenvalue of the Laplacian.
RR-3701.pdf (414.13 Ko) Télécharger le fichier
Dates and versions
inria-00072967 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00072967 , version 1
Cite
Gilles Fremiot, Jan Sokolowski. Shape Sensitivity Analysis of Variational Problems in Domains with Cracks. [Research Report] RR-3701, INRIA. 1999, pp.42. ⟨inria-00072967⟩
110 View
85 Download
Share
