A Performance Evaluation of Alternative Mapping Schemes for Storing XML Data in a Relational Database - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
XML is emerging as one of the dominant data formats for data processing on the Internet. To query XML data, query languages like XQL, Lorel, XML-QL, or XML-GL have been proposed. In this paper, we study how XML data can be stored and queried using a standard relational database system. For this purpose, we present alternative mapping schemes to store XML data in a relational database and discuss how XML-QL queries can be translated into SQL queries for every mapping scheme. We present the results of comprehen- sive performance experiments that analyze the tradeoffs of the alternative mapping schemes in terms of database size, query performance and update performance. % The results show clearly that a variant of a binary mapping scheme % shows the overall best performance While our discussion is focussed on XML and XML-QL, the results of this paper are relevant for most semi-struct- ured data models and most query languages for semi-structured data.
Autre [cs.OH]
RR-3680.pdf (390.91 Ko) Télécharger le fichier
inria-00072991 , version 1 (24-05-2006)
  • HAL Id : inria-00072991 , version 1
Daniela Florescu, Donald Kossmann. A Performance Evaluation of Alternative Mapping Schemes for Storing XML Data in a Relational Database. [Research Report] RR-3680, INRIA. 1999. ⟨inria-00072991⟩
682 Consultations
549 Téléchargements
