Reports
Multiphase Evolution and Variational Image Classification
Christophe Samson 1 Laure Blanc-Féraud Gilles Aubert Josiane Zerubia
1 ARIANA - Inverse problems in earth monitoring
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - SIS - Signal, Images et Systèmes
Abstract : This report presents a supervised classification model based on a variational approach. This model is devoted to find an optimal partition compound of homogeneous classes with regular interfaces. We represent the regions of the image defined by the classes and their interfaces by level set functions, and we define a functional whose minimum is an optimal partition. The coupled Partial Differential Equations (PDE) related to the minimization of the functional are considered through a dynamical scheme. Given an initial interface set (zero level set), the different terms of the PDE's are governing the motion of interfaces such that, at convergence, we get an optimal partition as defined above. Each interface is guided by internal forces (regularity of the interface), and external ones (data term, no vacuum, no regions overlapping). We conducted several experiments on both synthetic an real images.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073010
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:34:56 AM
Last modification on : Friday, February 4, 2022 - 3:08:38 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:31:19 PM
Identifiers
  • HAL Id : inria-00073010, version 1
Citation
Christophe Samson, Laure Blanc-Féraud, Gilles Aubert, Josiane Zerubia. Multiphase Evolution and Variational Image Classification. RR-3662, INRIA. 1999. ⟨inria-00073010⟩
Share
Metrics
Record views
153
Files downloads
212
