MBTT Inversion with a Poor Initial Velocity Background: Optimization Strategies? Density of Shots?
Abstract : The Migration-Based TravelTime (MBTT) reformulation of the classical least-squ- ares waveform inversion problem enlarges the attraction domain for the global minimum of the data misfit function, but does not make it convex. Systematic experimentation on the possible strategies to perform the minimizat- ion of the criterion with respect to the new MBTT unknowns (the propagator and the time reflectivity) is presented on a non-layered synthetic example with a finite-difference acoustic simulator. The influence of the amount of available data on the enlargement of the attraction domain is also investigated.
Type de document :
Rapport
[Research Report] RR-3657, INRIA. 1999
Liste complète des métadonnées
https://hal.inria.fr/inria-00073016
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 11:36:11
Dernière modification le : mardi 17 avril 2018 - 11:25:14
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:31:26
Fichiers
  • HAL Id : inria-00073016, version 1
Collections
Citation
François Clément. MBTT Inversion with a Poor Initial Velocity Background: Optimization Strategies? Density of Shots?. [Research Report] RR-3657, INRIA. 1999. 〈inria-00073016〉
Métriques
Consultations de la notice
155
Téléchargements de fichiers
140
