Abstract : This paper presents a software infrastructure for component programming on SCI-based Clusters. This environment is based on the concept of Parallel CORBA object that is an extension to the Common Object Request Broker Architecture (CORBA) from the OMG (Object Management Group). The proposed extensions do not modified the CORBA core infrastructure (the Object Request Broker) so that it can fully co-exist with existing CORBA applications. A signal processing application is presented to illustrate the use of this software infrastructure.
https://hal.inria.fr/inria-00073023 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2006 - 11:37:30 AM Last modification on : Friday, February 4, 2022 - 3:22:09 AM Long-term archiving on: : Sunday, April 4, 2010 - 11:31:34 PM
