New interface
Reports
Static Analysis of Java for Distributed and Parallel Programming
Isabelle Attali 1 Denis Caromel Romain Guider
1 OASIS - Active objects, semantics, Internet and security
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : We investigate the use of static analysis for building distributed and parallel programs in Java. We first quickly explain a principle of seamless sequential, multithreaded and distributed programming using Java, in order to enhance code reuse and code evolution. We exhibit conditions on the graph of objects to detect activable objects and transform a sequential program into a distributed or parallel program using active objects. We then present a static analysis based on an abstract interpretation of a Java subset, which provides approximate sets of activable objects. Finally, we illustrate our algorithm and results with one example.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073040
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:40:46 AM
Last modification on : Thursday, August 4, 2022 - 4:52:46 PM
Long-term archiving on: : Sunday, April 4, 2010 - 9:37:52 PM
Identifiers
  • HAL Id : inria-00073040, version 1
Collections
Citation
Isabelle Attali, Denis Caromel, Romain Guider. Static Analysis of Java for Distributed and Parallel Programming. RR-3634, INRIA. 1999. ⟨inria-00073040⟩
Share
Metrics
Record views
94
Files downloads
166
