HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Cayley Graphs with Complete Rotations
Marie-Claude Heydemann 1 Nausica Marlin Stéphane Pérennes
1 SLOOP - Simulation, Object Oriented Languages and Parallelism
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : As it is introduced by Bermond, Pérennes, and Kodate and by Fragopoulou and Akl, some Cayley graphs, including most popular models for interconnection networks, admit a special automorphism, called complete rotation. Such an automorphism is often used to derive algorithms or properties of the underlying graph. For example, some optimal gossiping algorithms can be easily designed by using a complete rotation, and the constructions of the best known edge disjoint spanning trees in the toroidal meshes and the hypercubes are based on such an automorphism. Our purpose is to investigat- e such Cayley graphs. We relate some symmetries of a graph with potential algebraic symmetries appearing in its definition as a Cayley graph on a group. In the case of Cayley graphs defined on a group generated by transpositions, we characterize the ones admitting a complete rotation.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073053
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 11:42:30 AM
Last modification on : Friday, February 4, 2022 - 3:20:12 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:32:49 PM
Identifiers
  • HAL Id : inria-00073053, version 1
Collections
Citation
Marie-Claude Heydemann, Nausica Marlin, Stéphane Pérennes. Cayley Graphs with Complete Rotations. RR-3624, INRIA. 1999. ⟨inria-00073053⟩
Share
Metrics
Record views
74
Files downloads
182
