Et++ -an object oriented application framework in c++, OOPSLA'88, pp.46-57, 1988. ,
Obstacles in object-oriented software development, Proceedings of OOPSLA'92, pp.341-358, 1992. ,
DOI : 10.1145/141937.141965
Developing object-oriented frameworks using domain models, 1997. ,
DOI : 10.1145/351936.351947
URL : http://eprints.eemcs.utwente.nl/8902/01/Developing_OO_Frameworks_using_Domain_Models.pdf
Patterns and software: Essential concepts and terminology. Object Magazine Online, 1997. ,
Assessment of application framework maturity using design metrics, pp.205-890, 1997. ,
Framework development for large systems, Communications of the ACM, vol.40, issue.10, pp.52-59, 1997. ,
DOI : 10.1145/262793.262804
Business process components for distributed object applications, Communications of the ACM, vol.41, issue.6, pp.43-48, 1998. ,
DOI : 10.1145/276609.276618
Agent technology: A new frontier for the development of application frameworks, Object Oriented Application Frameworks, 1998. ,
Towards agent oriented application frameworks, ACM Computing Surveys, vol.32, issue.1es, 1998. ,
DOI : 10.1145/351936.351957
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.8173
From custom applications to domain-specific frameworks, Communications of the ACM, vol.40, issue.10, 1997. ,
DOI : 10.1145/262793.262807
Design guidelines for ???tailorable??? frameworks, Communications of the ACM, vol.40, issue.10, pp.60-64, 1997. ,
DOI : 10.1145/262793.262805
A high-level and flexible framework for implementing multiuser user interfaces, ACM Transactions on Information Systems, vol.10, issue.4, pp.345-380, 1992. ,
DOI : 10.1145/146486.146495
Oodce: A c++ framework for the osf distributed computing environment, Proceedings of the Winter USENIX Conference. USENIX Association, 1995. ,
SEMATECH's experiences with the CIM framework, Communications of the ACM, vol.40, issue.10, pp.82-84, 1997. ,
DOI : 10.1145/262793.262809
Object-oriented application frameworks, Communications of the ACM, vol.40, issue.10, pp.32-38, 1997. ,
DOI : 10.1145/262793.262798
BAST: A framework for reliable distributed computing, 1997. ,
Design Patterns: Elements of Reusable Object-Oriented Software, 1995. ,
Corona, Proceedings of the 1996 ACM conference on Computer supported cooperative work , CSCW '96, pp.140-149, 1996. ,
DOI : 10.1145/240080.240238
Contracts: Specifying behavioural compositions in object-oriented systems, Proceedings of ECOOP/OOPSLA'90, pp.169-180, 1990. ,
DOI : 10.1145/97945.97967
Particle Beam Dynamics Simulations Using the POOMA Framework, Proceedings from ISCOPE98. ISCOPE, 1998. ,
DOI : 10.1016/0021-9991(69)90058-8
The x-Kernel: an architecture for implementing network protocols, IEEE Transactions on Software Engineering, vol.17, issue.1, pp.64-76, 1991. ,
DOI : 10.1109/32.67579
An object-oriented framework for data parallelism, ACM Computing Surveys, 1998. ,
Object-Oriented Application Frameworks, chapter EPEE: A Framework for Supercomputing, 1998. ,
Distributed computing environment framework technical paper, 1991. ,
Documenting frameworks using patterns, Proceedings of OOPSLA 92 Vancouver , B.C. Canada, pp.63-76, 1992. ,
Issues in the design and specifications of class libraries, Proceedings of OOPSLA '92, pp.435-451, 1992. ,
InterViews: A C++ graphical interface toolkit ,
Reifying quality of service contracts for distributed software, 26th Conference on Technology of Object-Oriented Systems (TOOLS USA'98), 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-00776458
The publish/subscribe paradigm for scalable group collaboration systems, 1995. ,
Synchronisation constraints with inheritance: What is not possible -so what is?, 1992. ,
A note on inheritance and state machines, ACM SIGSOFT Software Engineering Notes, vol.18, issue.4, pp.61-69, 1993. ,
DOI : 10.1145/163626.163635
Applying 'design by contract', Computer, vol.25, issue.10, pp.40-52, 1992. ,
DOI : 10.1109/2.161279
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.72.7831
Designing reliable systems from reliable components using the context-dependent constraint concept, Proceedings of ISSRE '96: 7th International Symposium on Software Reliability Engineering, pp.142-151, 1996. ,
DOI : 10.1109/ISSRE.1996.558738
Verifying framework-based applications by establishing conformance, 1996. ,
Deputy mechanisms for object oriented databases, Proceedings of the IEEE 11th Conference on Data Engineering, 1995. ,
Rpc in the x-kernel: Evaluating new design techniques, Proceedings of the ACM Symposium on Operating Systems Principles, pp.91-101, 1989. ,
User Interface Management Systems, 1985. ,
DOI : 10.1007/978-3-642-70041-5
An adaptive framework for developing multimedia software components, Communications of the ACM, vol.40, issue.10, pp.43-47, 1997. ,
DOI : 10.1145/262793.262802
A stream input-output system, AT&T Bell Labs Technical Journal, vol.63, pp.311-324, 1984. ,
Systematic framework design by generalization, Communications of the ACM, vol.40, issue.10, pp.48-51, 1997. ,
DOI : 10.1145/262793.262803
The adaptive communication environment -an object oriented network programming toolkit for developing communication software, Sun User Group Conferences, 1993. ,
Designing object-oriented synchronous groupware with COAST, Proceedings of the 1996 ACM conference on Computer supported cooperative work , CSCW '96, pp.30-38 ,
DOI : 10.1145/240080.240186
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.50.967
Framework, design patterns and pattern language for object concurrency, Proceedings of the International Conference on Parallel and Distributed Processing Techniques and Applications, 1997. ,
CORBA: integrating diverse applications within distributed heterogeneous environments, IEEE Communications Magazine, vol.35, issue.2, 1997. ,
DOI : 10.1109/35.565655
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.145.6098
Writing frameworks -capturing your expertise about a problem domain, Tutorial Notes, OOPSLA'93, 1993. ,
The conduit: A communication abstraction in c++, Proceedings of the 2nd USENIX C++ Conference, pp.191-203, 1990. ,
Campus scientifique, 615 rue du Jardin Botanique Irisa, Campus universitaire de Beaulieu, 35042 RENNES Cedex Unité de recherche INRIA Rhône-Alpes, p.78153, 2004. ,
