Generalization of the Grad Theory to Polyatomic Gases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
We generalize the Grad theory to polyatomic gases with a continuous internal energy. To this end, we consider the generalized Borgnakke-Larsen model, and also a model derived of a monoatomic gas in dimension higher than three. We give an explicit fourteen moments system, computed for a diatomic gas and a Hard Sphere potential. Finally, we show how it can be reduced to standard Navier-Stokes equations.
Autre [cs.OH]
RR-3581.pdf (303.27 Ko) Télécharger le fichier
inria-00073100 , version 1 (24-05-2006)
  • HAL Id : inria-00073100 , version 1
François Mallinger. Generalization of the Grad Theory to Polyatomic Gases. [Research Report] RR-3581, INRIA. 1998. ⟨inria-00073100⟩
125 Consultations
160 Téléchargements
