ON/OFF Sources in an Interconnection Network: Performance Analysis when Packets are Routed to the Shortest Queue of two Randomly Selected Nodes - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1998
The authors investigate a system with N servers and with N sources connected with the servers. A sources can be in state «on» or «off». In state «on» the source generates the Poisson flow of packets of rate $\lb$. The service time of a packet is distributed exponentially with mean one. Upon its arrival a packet is directed to the server with the shortest queues of the following two servers: the server where the packet has been generated and another randomly selected server. The queue length probability as N \to \infty$ is investigated.
RR-3570.pdf (362.2 Ko) Télécharger le fichier
Dates and versions
inria-00073111 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073111 , version 1
Cite
Philippe Jacquet, Nikita Vvedenskaya. ON/OFF Sources in an Interconnection Network: Performance Analysis when Packets are Routed to the Shortest Queue of two Randomly Selected Nodes. [Research Report] RR-3570, INRIA. 1998. ⟨inria-00073111⟩
170 View
51 Download
Share
