A Multithreaded Runtime Environment with Thread Migration for HPF and C* Data-Parallel Compilers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Luc Bougé
Phil Hatcher
  • Fonction : Auteur
Raymond Namyst
Christian Pérez
This paper studies the benefits of compiling data-parallel languages onto a multithreaded runtime environment providing dynamic thread migration facility. Each abstract process is mapped onto a thread, so that dynamic load balancing can be achieved by migrating threads among the processing nodes. We describe and evaluate an implementation of this idea in the Adaptor HPF and the UNH C* data-parallel compilers. We show that no deep modifications of the compilers are needed, and that the overhead of managing threads can be kept small. As an experimental validation, we report on an HPF implementation of the Gauss Partial Pivoting algorithm. We show that the initial BLOCK data distribution with our dynamic load balancing scheme can reach the performance of the optimal CYCLIC distribution.
Autre [cs.OH]
RR-3560.pdf (413.58 Ko) Télécharger le fichier
inria-00073123 , version 1 (24-05-2006)
  • HAL Id : inria-00073123 , version 1
Luc Bougé, Phil Hatcher, Raymond Namyst, Christian Pérez. A Multithreaded Runtime Environment with Thread Migration for HPF and C* Data-Parallel Compilers. [Research Report] RR-3560, INRIA. 1998. ⟨inria-00073123⟩
141 Consultations
279 Téléchargements
