Automatic Detection and Segmentation of Evolving Processes in 3D Medical Images: Application to Multiple Sclerosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Gérard Subsol
Hervé Delingette
Nicholas Ayache
Physicians often perform diagnoses based on the evolution of lesions, tumors or anatomical structures through time. The objective of this report is to automatically detect regions with apparent local volume variation with a vector field operator applied to the local displacement field obtained after a non-rigid registration between successive temporal images. In studying the information of apparent shrinking areas in the direct and reverse displacement fields between images, we are able to segment evolving lesions. Then we propose a method to segment lesions in a whole temporal series of images. In this report we apply this approach to the automatic detection and segmentation of multiple sclerosis lesions in time series of MRI images of the brain.
RR-3559.pdf (1.56 Mo) Télécharger le fichier
inria-00073125 , version 1 (24-05-2006)
  • HAL Id : inria-00073125 , version 1
David Rey, Gérard Subsol, Hervé Delingette, Nicholas Ayache. Automatic Detection and Segmentation of Evolving Processes in 3D Medical Images: Application to Multiple Sclerosis. RR-3559, INRIA. 1998. ⟨inria-00073125⟩
127 Consultations
393 Téléchargements
