Automatic Distribution of Reactive Systems for Asynchronous Networks of Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Paul Caspi
  • Fonction : Auteur
Alain Girault
  • Fonction : Auteur
  • PersonId : 833575
Daniel Pilaud
  • Fonction : Auteur
This paper addresses the problem of automatically distributing reactive systems. We first show that the use of synchronous languages allows a natural parallel description of such systems, regardless of any distribution problems. Then, a desired distribution can be easily specified, and achieved with the algorithm presented here. This distribution technique provides distributed programs with the same safety, test and debug facilities as ordinary sequential programs. Finally, the implementation of such distributed programs only requires a very simple communication protocol («first in first out» queues), thereby reducing the need for large distributed real-time executives.
RR-3491.pdf (329.2 Ko) Télécharger le fichier
inria-00073196 , version 1 (24-05-2006)
  • HAL Id : inria-00073196 , version 1
Paul Caspi, Alain Girault, Daniel Pilaud. Automatic Distribution of Reactive Systems for Asynchronous Networks of Processors. RR-3491, INRIA. 1998. ⟨inria-00073196⟩
54 Consultations
155 Téléchargements
