Image analysis and Markov fields, in Int, Conf. on Ind. and Appl. Math. SIAM Paris, SIAM Philadelphia, 1988. ,
Spatial Interaction and Statistical Analysis of Lattice Systems, A. Roy, Stat. Soc. Series B, vol.36, pp.721-741, 1974. ,
Assessing Convergence of Markov Chain Monte Carlo Algorithms, 1997. ,
Reconstruction d'image : régularisation avec prise en compte des discontinuités, 1994. ,
Deterministic edge-preserving regularization in computed imaging, IEEE Transactions on Image Processing, vol.6, issue.2, pp.298-311, 1997. ,
DOI : 10.1109/83.551699
Image restoration using an estimated Markov model, Signal Processing, vol.15, issue.2, pp.115-129, 1988. ,
DOI : 10.1016/0165-1684(88)90065-5
Idier : Unsupervised deconvolution of sparse spike train using stochastic approximation, IEEE Trans. on Image Processing, vol.44, issue.12, 1996. ,
Robustness of automated data choices of smoothing parameter in image regularization, Statistics and Computing, vol.55, issue.4, 1996. ,
DOI : 10.1007/BF00143557
Image reconstruction and restoration: overview of common estimation structures and problems, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.12, 1989. ,
DOI : 10.1109/29.45551
Estimation of Markov random field prior parameters using Markov chain Monte Carlo maximum likelihood, et IEEE Trans. on Image Proc. à paraître en, 1996. ,
DOI : 10.1109/83.772239
URL : https://hal.archives-ouvertes.fr/inria-00073679
Rate of convergence of the Swendsen-Wang dynamics in image segmentation problems : a theoretical and experimental study, ESAIM : Probability and Statistics, Soc. de Math. Appli. et Ind, vol.1, pp.259-284, 1997. ,
Stochastic relaxation, Gibbs distributions, and the Bayesian restoration of images, IEEE Trans. Patt. Anal. Machine intell, vol.6, issue.6, pp.721-741, 1984. ,
Random fields and inverse problems in imaging, 1990. ,
DOI : 10.1109/TPAMI.1987.4767898
Constrained restoration and the recovery of discontinuities, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.3, pp.367-383, 1992. ,
DOI : 10.1109/34.120331
Nonlinear image recovery with half-quadratic regularization, IEEE Transactions on Image Processing, vol.4, issue.7, pp.932-946, 1995. ,
DOI : 10.1109/83.392335
Gibbs Measures and Phase Transitions, Gruyter -Studies in Mathematics, vol.9, 1988. ,
Constrained Monte Carlo Maximum Likelihood for dependent data, J. R. Statist. Soc. B, vol.54, issue.3, pp.657-699, 1992. ,
Markov Chain Monte Carlo Maximum Likelihood, 1993. ,
On the convergence of Monte Carlo Maximum Likelihood calculations, J. R. Statist. Soc. B Vol, vol.56, issue.1, pp.261-274, 1994. ,
Spiegelhalter : Markov Chain Monte Carlo in practice, 1996. ,
Wefelmeyer : Outperforming the Gibbs Sampler Empirical Estimator of Nearest Neighbour Random Fields, 1995. ,
Monte Carlo sampling methods using Markov chains and their applications, Biometrika, vol.57, issue.1, pp.97-109, 1970. ,
DOI : 10.1093/biomet/57.1.97
Auxiliary variable methods for Markov Chain Monte Carlo with applications, submitted to JASA Theory and Methods, revised version, 1997. ,
Difficulties in the use of auxiliary variables in Markov Chain Monte Carlo methods, Statistics and Computing, vol.7, issue.1, pp.35-44, 1997. ,
DOI : 10.1023/A:1018505328451
Zerubia : Unsupervised deconvolution of satellite images, IEEE Int. Conference on Image Processing, pp.4-7, 1998. ,
Simultaneous parameter estimation and segmentation of Gibbs random fields using simulated annealing, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.8, pp.799-813, 1989. ,
DOI : 10.1109/34.31443
Metropolized Gibbs sampler : an improvement, 1996. ,
Tweedie : Rates of convergence of the Hastings and Metropolis algorithms, 1994. ,
Equation of State Calculations by Fast Computing Machines, The Journal of Chemical Physics, vol.21, issue.6, pp.1087-1092, 1953. ,
DOI : 10.1063/1.1699114
Zerubia : An Analysis of Some Models Used in Image Segmentation, 1996. ,
Zerubia : Fully Bayesian image segmentation an engineering perspective, 1996. ,
Numerical Recipes in C : The Art of Scientific Computing, 1993. ,
Numerical Bayesian methods applied to signal processing, Statistics and Computing, 1996. ,
DOI : 10.1007/978-1-4612-0717-7
Méthodes de Monte Carlo par chaînes de Markov, 1996. ,
Nonuniversal critical dynamics in Monte Carlo simulations, Physical Review Letters, vol.58, issue.2, pp.86-88, 1987. ,
DOI : 10.1103/PhysRevLett.58.86
Tools for statistical inference, 1996. ,
Regularization of incorrectly posed problems, Sov. Math. Dokl, vol.4, pp.1624-1627, 1963. ,
Estimation and annealing for Gibbsian fields, Ann. Inst. Poincaré, vol.24, issue.2, pp.269-294, 1988. ,
Parametric inference for imperfectly observed Gibbsian fields, Prob. Th. Fields, pp.625-645, 1989. ,
Synchronous random fields and image restoration, rapport CMLA, 1996. ,
Bayesian Inference for Inverse Problems , part of SPIE's Int jul. 1998. INRIA 2004, route des Lucioles -B.P. 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Lorraine : Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -B.P. 101 -54602 Villers lès Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38330 Montbonnot St Martin (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -B.P. 105 -78153 Le Chesnay Cedex, pp.19-24 ,
105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
