Stereo Calibration from Rigid Motions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
This paper describes a method to upgrade projective reconstruction to affine and to metric reconstructions using rigid general or planar motions of a stereo rig. We make clear the algebraic relationships between projective reconstruction, the plane at infinity (affine reconstruction), camera calibration, and metric reconstruction when a 3-D scene is observed with a moving stereo rig. Based on an in-depth algebraic analysis we show that all the computations can be carried out using standard linear resolution methods. We carry out a theoretical error analysis which quantify the relative importance of the accuracies of projective-to-affine conversion and affine-to-Euclidean conversion. Extensive experiments performed with calibrated and natural data confirm the theoretical error analysis and are consistent with a sensitivity analysis performed with simulated data.
RR-3467.pdf (160.19 Ko) Télécharger le fichier
inria-00073223 , version 1 (24-05-2006)
  • HAL Id : inria-00073223 , version 1
Radu Horaud, Gabriella Csurka, David Demirdjian. Stereo Calibration from Rigid Motions. RR-3467, INRIA. 1998. ⟨inria-00073223⟩
113 Consultations
129 Téléchargements
