On a Reduced Load Equivalence for Fluid Queues Under Subexponentiality
Abstract : We propose a general framework for obtaining asymptotic distributional bounds on the stationary backlog $W^{A_1+A_2,c}$ in a buffer fed by a combined fluid process $A_1+A_2$ and drained at a constant rate $c$. The fluid process $A_1$ is an (independent) on-off source with average and peak rates $\rho_1$ and $r_1$, respectively, and with distribution $G$ for the activity periods. The fluid process $A_2$ of average rate $\rho_2$ is arbitrary but independent of $A_1$. These bounds are used to identify subexponential distributions $G$ and fairly general fluid processes $A_2$ such that the asymptotic equivalence $\bP{W^{A_1+A_2,c}>x} \sim \bP{W^{A_1,c-\rho_2}>x}$ ($x\to\infty$) holds under the stability condition $\rho_1+\rho_2
Type de document :
Rapport
RR-3466, INRIA. 1998
Liste complète des métadonnées
Littérature citée [29 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00073224
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 12:14:59
Dernière modification le : samedi 27 janvier 2018 - 01:31:31
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:38:50
Fichiers
  • HAL Id : inria-00073224, version 1
Collections
Citation
Rajeev Agrawal, Armand M. Makowski, Philippe Nain. On a Reduced Load Equivalence for Fluid Queues Under Subexponentiality. RR-3466, INRIA. 1998. 〈inria-00073224〉
Métriques
Consultations de la notice
132
Téléchargements de fichiers
145
