Asymptotics of the Perron Eigenvalue and Eigenvector Using Max-Algebra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
We consider the asymptotics of the Perron eigenvalue and eigenvector of irreducible nonnegative matrices whose entries have a geometric dependance in a large parameter. The first term of the asymptotic expansion of these spectral elements is solution of a spectral problem in a semifield of jets, which generalizes the max-algebra. We state a «Perron-Frobenius theorem» in this semifield, which allows us to characterize the first term of this expansion in some non-singular cases. The general case involves an aggregation procedure à la Wentzell-Freidlin.
RR-3450.pdf (148.76 Ko) Télécharger le fichier
inria-00073240 , version 1 (24-05-2006)
  • HAL Id : inria-00073240 , version 1
Marianne Akian, Ravindra Bapat, Stéphane Gaubert. Asymptotics of the Perron Eigenvalue and Eigenvector Using Max-Algebra. [Research Report] RR-3450, INRIA. 1998. ⟨inria-00073240⟩
177 Consultations
410 Téléchargements
