Performance bounds for guaranteed and adaptive services, 1996. ,
Ergodic theory of stochastic Petri networks, The Annals of Probability, pp.375-396, 1992. ,
Elements of Queueing Theory, 1994. ,
DOI : 10.1007/978-3-662-11657-9
On the saturation rule for the stability of queues, Journal of Applied Probability, vol.12, issue.02, pp.494-507, 1995. ,
DOI : 10.1214/aoap/1177005203
URL : https://hal.archives-ouvertes.fr/inria-00074656
TCP Vegas: end to end congestion avoidance on a global Internet, IEEE Journal on Selected Areas in Communications, vol.13, issue.8, pp.1465-1480, 1995. ,
DOI : 10.1109/49.464716
Internetworking with TCP-IP (Volume I) : principles, protocols and architecture, 1995. ,
On traffic phase effects in packet-switched gateways, Internetworking: Research and Experience, pp.115-156, 1992. ,
Subadditive ergodic theory, The Annals of Probability, pp.883-909, 1973. ,
Performance analysis of window-based flow control using TCP/IP: The effect of high bandwidth-delay products and random loss, Proceedings HPN'94, pp.135-150, 1994. ,
Optimal flow control of a class of queueing networks in equilibrium, IEEE Transactions on Automatic Control, vol.28, issue.11, pp.1001-1007, 1983. ,
DOI : 10.1109/TAC.1983.1103166
The stability of a queue with non-independent inter-arrival and service times, Proc. Camb, pp.497-520, 1962. ,
DOI : 10.2307/1992945
Asymptotically optimal design of congestion control for high speed data networks, IEEE Transactions on Communications, vol.40, issue.2, pp.301-311, 1992. ,
DOI : 10.1109/26.129192
Window size behavior in TCP/IP with constant loss probability, DIMACS Workshop on Performance of Real-time Applications on the Internet, 1996. ,
Some observations on the dynamics of a congestion control algorithm, ACM SIGCOMM Computer Communication Review, vol.20, issue.5, pp.30-39, 1990. ,
DOI : 10.1145/381906.381931
Self-similarity through high variability: Statistical analysis and Ethernet LAN traffic at the source level, Proceedings of ACM SIGCOMM'95, 1995. ,
105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
