A Framework for Parallel Programming in Java - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
To ease the task of programming parallel and distributed applications, the Do! project aims at the automatic generation of distributed code from multi-threaded Java programs. We provide a parallel programming model, embedded in a framework that constraints parallelism without any extension to the Java language. This framework is described here and is used as a basis to generate distributed programs.
Autre [cs.OH]
RR-3319.pdf (216.59 Ko) Télécharger le fichier
inria-00073370 , version 1 (24-05-2006)
  • HAL Id : inria-00073370 , version 1
Pascale Launay, Jean-Louis Pazat. A Framework for Parallel Programming in Java. [Research Report] RR-3319, INRIA. 1997. ⟨inria-00073370⟩
138 Consultations
867 Téléchargements
