Analysis of a Guard Condition in Type Theory (Preliminary Report) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
Solange Coupet-Grimal
  • Fonction : Auteur
  • PersonId : 833596
We present a realizability interpretation of co-inductive types based on partial equivalence relations (per's). We extract from the per's interpreta- tion sound rules to type recursive definitions. These recursive definitions are needed to introduce «infinite» and «total» objects of co-inductive type such as an infinite stream or a non-terminating process. We show that the proposed type system enjoys the basic syntactic properties of subject reduction and strong normalization with respect to a confluent rewriting system first studied by Gimenez. We also compare the proposed type system with those studied by Coquand and Gimenez. In particular, we provide a semantic reconstruction of Gimenez's system which suggests a rule to type nested recursive definitions.
Mots clés
Autre [cs.OH]
RR-3300.pdf (350.17 Ko) Télécharger le fichier
inria-00073388 , version 1 (24-05-2006)
  • HAL Id : inria-00073388 , version 1
Roberto M. Amadio, Solange Coupet-Grimal. Analysis of a Guard Condition in Type Theory (Preliminary Report). RR-3300, INRIA. 1997. ⟨inria-00073388⟩
62 Consultations
126 Téléchargements
