Bitwise Regularity Coefficients as a Tool for Deception Analysis of a Genetic Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
We present in this paper a theoretical analysis that relates an irregularity measure of a fitness function to the so-called GA-deception. This approach is a con­ti­nua­tion of a work that has presented a deception a­na­ly­sis of Hölder functions. The analysis developed here is a generalization of this work in two ways¸: we first use a «bitwise regularity» instead of a Hölder exponent as a basis for our deception analysis, second, we perform a similar deception analysis of a GA with uniform crossover. We finally propose to use the bitwise regularity coefficients in order to analyze the influence of a chromosome encoding on the GA efficiency, and present experiments with bits permutations and Gray encoding.
RR-3274.pdf (471.84 Ko) Télécharger le fichier
inria-00073415 , version 1 (24-05-2006)
  • HAL Id : inria-00073415 , version 1
Benoît Leblanc, Evelyne Lutton. Bitwise Regularity Coefficients as a Tool for Deception Analysis of a Genetic Algorithm. [Research Report] RR-3274, INRIA. 1997. ⟨inria-00073415⟩
54 Consultations
229 Téléchargements
