New interface
Reports (Research report)
On the Analysis of Linear Probing Hashing
Philippe Flajolet 1 Patricio Poblete Alfredo Viola
1 ALGO - Algorithms
Inria Paris-Rocquencourt
Abstract : This paper presents moment analyses and characterizations of limit distributions for the construction cost of hash table under the linear probing strategy. Two models are considered, that of full tables and that of sparse tables with a filling ratio strictly smaller than~1. For full tables, the construction cost has expectation $O(n^3/2)$, the standard deviation is of the same order, and a limit law of the Airy type holds. (The Airy distribution is a semi-classical distribution that is defined in terms of the usual Airy functions or equivalently in terms of Bessel functions of indices $-\frac{1}{3},\frac{2}{3}$.) For sparse tables, the construction cost has expectation $O(n)$, standard deviation $O(\sqrt{n})$, and a limit law of the Gaussian type. Combinatorial relations with other problems leading to Airy phenomena (like graph connectivity, tree inversions, tree path length, or area under excursions) are also briefly discussed.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00073424
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 12:46:40 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:48 AM
Long-term archiving on: : Thursday, March 24, 2011 - 12:43:06 PM
Identifiers
  • HAL Id : inria-00073424, version 1
Collections
Citation
Philippe Flajolet, Patricio Poblete, Alfredo Viola. On the Analysis of Linear Probing Hashing. [Research Report] RR-3265, INRIA. 1997. ⟨inria-00073424⟩
Share
Metrics
Record views
105
Files downloads
286
