On-Board Component Fault Detection and Isolation Using the Statistical Local Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Michèle Basseville
We describe both the key principles and real application examples of a unified theory which allows us to perform the on-board incipient fault detection and isolation tasks involved in monitoring for condition-based maintenance. We stress that, when designing detection algorithms, the main conceptual task is to select a convenient estimating function. ML, LS, IV and subspace identification methods are addressed in this perspective.
RR-3252.pdf (611.04 Ko) Télécharger le fichier
inria-00073437 , version 1 (24-05-2006)
  • HAL Id : inria-00073437 , version 1
Michèle Basseville. On-Board Component Fault Detection and Isolation Using the Statistical Local Approach. [Research Report] RR-3252, INRIA. 1997. ⟨inria-00073437⟩
296 Consultations
783 Téléchargements
