Homogenization of the Vlasov Equation and of the Vlasov - Poisson System with a Strong External Magnetic Field - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 1998
Motivated by the difficulty arising in the numerical simulation of the movement of charged particles in presence of a large external magnetic field, which adds an additional time scale and thus imposes to use a much smaller time step, we perform in this paper a homogenization of the Vlasov equation and of the Vlasov-Poisson system which yield approximate equations describing the mean behavior of the particles. The convergence proof is based on the two scale convergence tools introduced by N'Guetseng and Allaire. We also consider the case where, in addition to the magnetic field, a large external electric field orthogonal to the magnetic field and of the same magnitude is applied.
101117vpois.pdf (190.81 Ko) Télécharger le fichier
inria-00073462 , version 1 (24-05-2006)
inria-00073462 , version 2 (18-11-2010)
  • HAL Id : inria-00073462 , version 2
  • ARXIV : 1011.4282
Emmanuel Frénod, Eric Sonnendrücker. Homogenization of the Vlasov Equation and of the Vlasov - Poisson System with a Strong External Magnetic Field. Asymptotic Analysis, 1998, 18 (3-4), pp.193--214. ⟨inria-00073462v2⟩
154 Consultations
166 Téléchargements
