Analytic Combinatorics of Non-crossing Configurations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Marc Noy
  • Fonction : Auteur
This paper describes a systematic approach to the enumeration of «non-crossing» geometric configurations built on vertices of a convex $n$-gon in the plane. It relies on generating functions, symbolic methods, singularity analysis, and singularity perturbation. A consequence is exact and asymptotic counting results for trees, forests, graphs, connected graphs, dissections, and partitions. Limit laws of the Gaussian type are also established in this framework; they concern a variety of parameters like number of leaves in trees, number of components or edges in graphs, etc.
Autre [cs.OH]
RR-3196.pdf (525.16 Ko) Télécharger le fichier
inria-00073493 , version 1 (24-05-2006)
  • HAL Id : inria-00073493 , version 1
Philippe Flajolet, Marc Noy. Analytic Combinatorics of Non-crossing Configurations. [Research Report] RR-3196, INRIA. 1997. ⟨inria-00073493⟩
63 Consultations
221 Téléchargements
