Shape Optimization Problem for Heat Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Antoine Henrot
  • Fonction : Auteur
  • PersonId : 833598
In this paper the support of a Radon measure is selected in an optimal way. The solution of the parabolic equation depends on the mesure via the mixed type boundary conditions. The existence of a solution for a class of domain optimization problems is shown. We also investigate the behaviour of the optimal solution for some time $T$, when $T\to\infty$ and we prove that it converges to the optimal solution of the stationary problem. The first order necessary optimality conditions are derived.
Autre [cs.OH]
RR-3185.pdf (276.71 Ko) Télécharger le fichier
inria-00073504 , version 1 (24-05-2006)
  • HAL Id : inria-00073504 , version 1
Antoine Henrot, Jan Sokolowski. Shape Optimization Problem for Heat Equation. [Research Report] RR-3185, INRIA. 1997, pp.23. ⟨inria-00073504⟩
97 Consultations
432 Téléchargements
