Graph Problems Arising from Wavelength-Routing in All-Optical Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
Jean-Claude Bermond
Luisa Gargano
  • Fonction : Auteur
Pavol Hell
  • Fonction : Auteur
Stéphane Pérennes
  • Fonction : Auteur
  • PersonId : 942945
Ugo Vaccaro
  • Fonction : Auteur
We survey the theoretical results obtained for wavelength routing in all--optical networks, present some new results and propose several open problems. In all--optical networks the vast bandwidth available is utilized through {\em wavelength division multiplexing}~: a single physical optical link can carry several logical signals, provided that they are transmitted on different wavelengths. The information, once transmitted as light, reaches its destination without being converted to electronic form in between, thus reaching high data transmission rates. We consider both networks with arbitrary topologies and particular networks of practical interest.
Autre [cs.OH]
RR-3165.pdf (148.1 Ko) Télécharger le fichier
inria-00073523 , version 1 (24-05-2006)
  • HAL Id : inria-00073523 , version 1
Bruno Beauquier, Jean-Claude Bermond, Luisa Gargano, Pavol Hell, Stéphane Pérennes, et al.. Graph Problems Arising from Wavelength-Routing in All-Optical Networks. RR-3165, INRIA. 1997. ⟨inria-00073523⟩
464 Consultations
543 Téléchargements
