Progress Report on Parallelism in MuPAD - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Christian Heckler
  • Fonction : Auteur
Torsten Metzner
  • Fonction : Auteur
Paul Zimmermann
MuPAD is a general purpose computer algebra system with two programming concepts for parallel processing: {\em micro-parallelism\/} for shared-memory machines and {\em macro-parallelism\/} for distributed architectures. This article describes language instructions for both concepts, the current state of implementation, together with some examples.
Autre [cs.OH]
RR-3154.pdf (241.94 Ko) Télécharger le fichier
inria-00073535 , version 1 (24-05-2006)
  • HAL Id : inria-00073535 , version 1
Christian Heckler, Torsten Metzner, Paul Zimmermann. Progress Report on Parallelism in MuPAD. [Research Report] RR-3154, INRIA. 1997. ⟨inria-00073535⟩
152 Consultations
158 Téléchargements
