Multi-Item Single Machine Scheduling Optimization. The Case with Piecewise Deterministic Demands - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1997
In this work we study the optimization of a production system comprising a multi-item single machine with piecewise deterministic demands. Demands can only take a finite number of values and the demand changes are described by Poisson processes. We present the theoretical characterization of the solution and a numerical procedure to solve it. We establish the rate of convergence of the discrete solution toward the original continuous solution.
RR-3144.pdf (412.07 Ko) Télécharger le fichier
Dates and versions
inria-00073545 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073545 , version 1
Cite
Elina Mancinelli, Roberto L.V. González. Multi-Item Single Machine Scheduling Optimization. The Case with Piecewise Deterministic Demands. [Research Report] RR-3144, INRIA. 1997. ⟨inria-00073545⟩
44 View
88 Download
Share
