Termination Proofs Using gpo Ordering Constraints : Extended Version - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
We present here an algorithm for proving termination of term rewriting systems by \gpo ordering constraint solving. The algorithm gives, as automatically as possible, an appropriate instance of the gpo generic ordering proving termination of a given system. Constraint solving is done efficiently thanks to a DAG shared term data structure.
Autre [cs.OH]
RR-3087.pdf (483.33 Ko) Télécharger le fichier
inria-00073604 , version 1 (24-05-2006)
  • HAL Id : inria-00073604 , version 1
Thomas Genet, Isabelle Gnaedig. Termination Proofs Using gpo Ordering Constraints : Extended Version. [Research Report] RR-3087, INRIA. 1997, pp.37. ⟨inria-00073604⟩
107 Consultations
112 Téléchargements
