. Références, Aussenac-Gilles, How to combine data abstraction and model refinement: a methodological contribution in MACAO, Proceedings of EKAW'94, Lecture Notes in AI N, pp.178-199, 1994.
S. Boyera and O. Corby, Etat de l'art sur la multi-expertise, Projet Génie Thème, vol.3, 1995.
]. F. Brazier, P. H. Van-langen, and J. Treur, Modelling conflict management in design: An explicit approach, Artificial Intelligence for Engineering, Design, Analysis and Manufacturing, vol.1, issue.04, pp.353-366, 1995.
DOI : 10.1017/S0890060400002882
. Breuker, Common-KADS Library for expertise modelling Reusable problem solving components, Frontiers in Artificial Intelligence and Applications, EDS), vol.94, 1994.
C. Chabaud, J. L. Soubie, F. Buratto, and N. Lompre, Cycle de vie des systemes a base de connaissances: Objets et methodes de validation ergonomiques, Rapport Interne IRIT, pp.91-139, 1991.
. Candrasekaran, Task-structure Analysis for Knowledge Modelling, Communications of the ACM, vol.35, issue.9, 1992.
. Easterbrook, A Survey of Empirical Studies of Conflict, CSCW: Cooperation or Conflict?
M. Nada and C. Olivier, Conflict management as part of an integrated exception handling approach, Artificial Intelligence for Engineering Design Analysis and Manufacturing, vol.9, pp.259-267, 1995.
. Matta, Le Schéma du modèle conceptuel, étape dans la modélisation des connaissances, Acquisition et Ingénierie des connaissances , N. Aussenac-Gilles, P. Laublet, C. Reynaud (Coordinateurs), Cépadués-Editions, 1996.
. Matta, Description de modèles de coopération et de gestion de conflits, pp.3-3, 1996.
A. Newell, The knowledge level, Artificial Intelligence, vol.18, issue.1, 1982.
DOI : 10.1016/0004-3702(82)90012-1
. B. Roy and . Roy, A conceptual Framework for a Normative Theory of Decision Aids, Management Science, 1976.
. T. Saaty and . Saaty, The analytic Hierarchy Process: Planning, Priority, Allocation, 1980.
W. Wielinga, A. Van-de-velde, and . Anjewierden, CML: The CommonKADS Conceptual Modelling Language, Proceedings of EKAW'94, Lecture Notes in AI N.867, pp.1-25, 1994.
. K. Sycara and . Sycara, Persuasive argumentation in negotiation, Theory and Decision, vol.12, issue.3, pp.203-242, 1990.
DOI : 10.1007/BF00162699
. K. Sycara and . Sycara, Cooperative Negotiation in Concurrent Engineering Design, Computer aided cooperative product development, Proceedings of MIT- JSME workshop, 1991.
