The Boundary-Value Problem in Domains with Very Rapidly Oscillating Boundary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
Avner Friedman
  • Fonction : Auteur
Andrey Piatnitski
  • Fonction : Auteur
The asymptotic behavior of solutions to the boundary-value problems posed in domains with very rapidly oscillating locally periodic boundary, is studied. For various kinds of boundary conditions the limiting problems are found and the estimates of the residual are given. Also, we construct an additional term of the asymptotics to improve the estimates of the residual.
Autre [cs.OH]
RR-3062.pdf (296.85 Ko) Télécharger le fichier
inria-00073630 , version 1 (24-05-2006)
  • HAL Id : inria-00073630 , version 1
Gregory Chechkin, Avner Friedman, Andrey Piatnitski. The Boundary-Value Problem in Domains with Very Rapidly Oscillating Boundary. RR-3062, INRIA. 1996. ⟨inria-00073630⟩
55 Consultations
1615 Téléchargements
