Tools for experiments in planning, Proceedings Sixth International Conference on Tools with Artificial Intelligence. TAI 94, pp.615-623, 1994. ,
DOI : 10.1109/TAI.1994.346436
The interaction of parallel and sequential workloads on a network of workstations, Proc. of the Joint Int. Conf. on Measurement & Modeling of Comp. Syst, 1995. ,
The SLOOP project: Simulations, Parallel Object-Oriented Languages, Interconnection Networks, 2nd European School of Computer Science, Parallel Programming Environments for High Performance Computing ESPPE'96, pp.85-88, 1996. ,
UNIX and load balancing : a survey, EUUG'89, 1989. ,
Presentation of a multicriteria load balancing, Proceedings of the Workshop on Dynamic Object Placement and Load Balancing in Parallel and Distributed Systems (ECOOP'92), 1992. ,
The influence of workload on load balancing strategies, USENIX Sum. Conf, 1986. ,
A hierarchical approach to workload characterization for parallel systems, LNCS EUROPE, issue.919, 1995. ,
DOI : 10.1007/BFb0046616
Efficient parallel computing in distributed workstation environments, Parallel Computing, vol.19, issue.11, pp.1221-1234, 1993. ,
DOI : 10.1016/0167-8191(93)90028-J
A tool for generating and modeling workloads in distributed workstations environments, Proceedings of Parallel and Distributed Computing Systems (PDCS'96) International Society for Computers and their Applications (ISCA). ISBN, pp.248-253, 1996. ,
A load index for dynamic load balancing, Proc. of the Fall Joint Computer Conf, pp.684-690, 1986. ,
The Art of computer performance analysis : techniques for experimental design, measurement, simulation and modeling, 1991. ,
Packet trains -measurements and a new model for computer network traffic, IEEE Journal on Selected Areas in Communications, issue.46, pp.986-995, 1986. ,
Load-balancing heuristics and process behavior, Perfor- mance'86 and ACM SIGMETRICS 1986, 1986. ,
DOI : 10.1145/317499.317539
Characterizing the resource demands of TCP/IP, LNCS, issue.919 ,
DOI : 10.1007/BFb0046613
Campus scientifique, 615 rue du Jardin Botanique, 2004. ,
