Coq en Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Coq en Coq
The essential step of the formal verification of a proof-checker such as Coq is the verification of its kernel: a type-checker for the Calculus of Inductive Constructions (CIC) which is its underlying formalism. The present work is a first small-scale attempt on a significative fragment of CIC: the Calculus of Constructions (CC). We formalize the definition and the metatheory of (CC) in Coq. In particular, we prove strong normalization and decidability of type inference. From the latter proof, we extract a certified Caml Light program, which performs type inference (or type-checking) for an arbitrary typing judgement in CC. Integrating this program in a larger system, including a parser and pretty-printer, we obtain a stand-alone proof-checker, called CoC, for the Calculus of Constructions. As an example, the formal proof of Newman's lemma, build with Coq, can be re-verified by CoC with reasonable performance.
Autre [cs.OH]
RR-3026.pdf (823.15 Ko) Télécharger le fichier
inria-00073667 , version 1 (24-05-2006)
  • HAL Id : inria-00073667 , version 1
Bruno Barras. Coq en Coq. [Research Report] RR-3026, INRIA. 1996. ⟨inria-00073667⟩
436 Consultations
478 Téléchargements
