Big Ray Tracing and Eikonal Solver on Unstructured Grids : Application to the Computation of a Multi-valued Travel-time Field in the Marmousi Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Remi Abgrall
  • Fonction : Auteur
  • PersonId : 833581
We present in this paper the numerical computation of the multi-valued travel-time field generated by a point source experiment in the Marmousi model. Two recently developed methods are combined to achieve this goal : a method called big ray tracing, used for the computation of multi-valued travel-time fields, and an eikonal solver designed to work on unstructured meshes.\\ Big ray tracing is based on a combination of ray tracing and local solutions of the eikonal equation. A classical ray tracing first 'discretizes' the phase space and defines local zones which possibly overlap where the travel-time field is multi-valued. An eikonal solver then computes the travel-time in these zones called big rays. It acts as an exact interpolator between rays associated to different branches of the travel-time field. The geometry of the big rays may be complicated and is best discretized using unstructured meshes. An eikonal solver designed to work on unstructured meshes is used.
RR-3019.pdf (6.69 Mo) Télécharger le fichier
inria-00073675 , version 1 (24-05-2006)
  • HAL Id : inria-00073675 , version 1
Remi Abgrall, Jean-David Benamou. Big Ray Tracing and Eikonal Solver on Unstructured Grids : Application to the Computation of a Multi-valued Travel-time Field in the Marmousi Model. [Research Report] RR-3019, INRIA. 1996. ⟨inria-00073675⟩
195 Consultations
751 Téléchargements
