Stability of Discrete-time Systems : New Criteria and Applications to Control Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Mohamed Bensoubaya
  • Fonction : Auteur
The aim of this article is to present some new stability sufficient conditions for discrete-time nonlinear systems. It shows how to use nonnegative semi-definite functions as Lyapunov functions instead of positive definite ones for studying the stability of a given system. Several examples and some applications to control theory are presented to illustrate the various theorems.
RR-3003.pdf (239.48 Ko) Télécharger le fichier
inria-00073692 , version 1 (24-05-2006)
  • HAL Id : inria-00073692 , version 1
Abderrahman Iggidr, Mohamed Bensoubaya. Stability of Discrete-time Systems : New Criteria and Applications to Control Problems. [Research Report] RR-3003, INRIA. 1996, pp.18. ⟨inria-00073692⟩
107 Consultations
5114 Téléchargements
