HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
SALTO : System for Assembly-Language Transformation and Optimization
Erven Rohou 1 François Bodin 1 André Seznec 1 Gwendal Le Fol 2 François Charot 2 Frédéric Raimbault 3
1 CAPS - Compilation, parallel architectures and system
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
2 API - Parallel VLSI Architectures
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : On critical applications, particularly embedded systems, the performance tuning requires multiple passes. SALTO (System for Assembly Language Transformation and Optimization) is a retargetable framework for developing all the spectrum of tools that are needed for performance tuning on low-level codes (assembly-languages) on uniprocessors. SALTO enables the building of profiling, tracing and optimization tools. The user is responsible for giving a machine description of the target architecture, which includes instruction-set of the processor, precise hardware configuration and reservation-tables for all instructions, but high-level functions are provided to him for writing any tool corresponding to his needs. Moreover SALTO will be a part of a global solution for manipulating assembly-code to implement low-level code restructuration as well as to provide a high-level code restructurer with useful information collected from the assembler code and from instruction profiling. SALTO has been tested on Intel platforms running Linux (i486) and Solaris (PentiumPro) and on a Sparcstation running SunOs 4.1. A machine description for the Sparc v7 architecture is currently available. Two examples, a basic block instrumentation and a local reordering optimization, are given in the paper as illustration.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073718
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 1:35:55 PM
Last modification on : Friday, February 4, 2022 - 3:31:25 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:55:58 PM
Identifiers
  • HAL Id : inria-00073718, version 1
Citation
Erven Rohou, François Bodin, André Seznec, Gwendal Le Fol, François Charot, et al.. SALTO : System for Assembly-Language Transformation and Optimization. [Research Report] RR-2980, INRIA. 1996. ⟨inria-00073718⟩
Share
Metrics
Record views
356
Files downloads
208
