Numerical Computation of a Polynomial GCD and Extensions - Archive ouverte HAL Access content directly
Reports Year : 1996
In the first part of this paper, we define approximate polynomial gcds (greatest common divisors) and extended gcds provided that approximations to the zeros of the input polynomials are available. We relate our novel definition to the older and weaker ones, based on perturbation of the coefficients of the input polynomials, we demonstrate some deficiency of the latter definitions (which our definition avoids), and we propose new effective sequential and parallel (RNC and NC) algorithms for computing approximate gcds and extended gcds. Our stronger results are obtained with no increase of the asymptotic bounds on the computational cost. This is partly due to application of our recent nearly optimal algorithms for approximating polynomial zeros. In the second part of our paper, working under the older and more customary definition of approximate gcds, we modify and develop an alternative approach, which was previously based on the computation of the Singular Value Decomposition (SVD) of the associated Sylvester (resultant) matrix. We observe that only a small part of the SVD computation is needed in our case, and we also yield further simplification by using the techniques of Padé approximation and computations with Hankel and Bezout matrices. Finally, in the last part of our paper, we show an extension of the numerical computation of the gcd to the problem of computing numerical rank of a Hankel matrix, which is a bottleneck of Padé and Berlekamp-Massey computations, having important applications to coding and transmission of information.
RR-2969.pdf (367.96 Ko) Télécharger le fichier
Dates and versions
inria-00073729 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073729 , version 1
Cite
Victor Y. Y. Pan. Numerical Computation of a Polynomial GCD and Extensions. RR-2969, INRIA. 1996. ⟨inria-00073729⟩
150 View
204 Download
Share
